1 - 7 of 7 Posts
I have a 92 yota pickup that is solid axle swapped and I was driving it while gathering parts for the full 4x4 swap as a 2wd. In the mean time I blew the original 22re, bent the crank. Figured it was a good time to bang out the 4x4 swap. Found a 4x4 trans and a top shift case, pulled the blown 22re and had a new 22re built up. I slapped it in not hooked up to trans/anything else and then life got in the way. Been sitting 2 years and I have 0 time to finish. At this point I am looking for a decent shop in New England area to finish the swap. Just a matter of hooking everything back up and mating the new trans to engine, proper crossmember and driveshaft lengths. Just want the thing drivable and that want has finally outweighed my pride. Any recommendations appreciated.
Where in CT are you? Don't know alot of yota guys, you could check with brent moser in ellington, valley truck and offroad.
Old School
Depending on where you are DMR Offroad in East Hampton, CT or Barrette Fabrication in Warwick, RI.
Discussion Starter #6
I am actually 5 minutes from DMR and constantly use them to mount/dismount my tires. Didn't know if they would take on a yota build as I think of them as Jeep guys. I'll have to ask Dan. Thanks
Slab King
I'll give a plug for The 4X4 Place in North NJ.
They can handle everything from oil changes to tube buggys.
1 - 7 of 7 Posts
