1 - 20 of 39 Posts
Questions:
1) Are you just announcing the product, or are you also offering a PBB discount?
2) Would you be able to make a set with all flush mount bolts (like you did for the two bottom bolts for the 'vise')? I have Avalanche corners and would like something that matches...they don't offer their rockers with the extra 'nerf'.
3) Would you be able to make a set for a CJ-8 without the cut-out at the front for the lip on the CJ fenders? I have YJ fenders on mine.
Thanks
Discussion Starter #4
Jeepskate:
10% off for PBB members
$25 for Stainless flush bolts down the side.
Is the CJ8 tub the same as a CJ7 b/t the wheel wells? Are the body mounts in the same location? If so, I can do it? If not it will require a little investigation.
JeremyH:
Shooting for the same price point on the TJ as the CJ. TJ will be ready in about 4weeks.
The CJ-8 tub is 10" longer between the wheelwells.
Yes, the body mounts are in the same locations (as a matter of fact, my tub is a graft of the original rear half & the front half of a YJ).
I have both vehicles (a CJ-7 and a CJ-8), so I can give you a full set of measurement differences at any point...shouldn't be any more involved than the extra 10" of length on the rocker, leaving out the notch for the fender lip, and a few extra inches of length on the tube. I realize that this, of course, adds to the cost.
You still around? Sent you an e-mail reply a week or two ago and haven't heard back from you...
-Rodney
No problem...I figured you probably got busy. I'll give you my update in the reply to your e-mail. Thanks.
-Rodney
Discussion Starter #16 (Edited)
OK, here is a teaser of the TJ prototype. Crappy pic but better pics and info will be available next week. The design is done so they will be ready for orders in a week.
Jim
Started stripping the CJ-7 yesterday, so I should be ready for the rockers right around the time they're due to arrive.
Couple questions
TJ pricing? Can you put in two support tubes like on the CJ products? Can I get them without "Schrockworks" cut out of them.
Discussion Starter #20 (Edited)
TJ price is the same, $298.
They ship with two supports like the CJ. This guy just wanted one.
It would actually cost about $40 more to remove the logo bec. I'd have to do a single unit run with the laser cutter, but it could be done.
1 - 20 of 39 Posts
