*NEW* JEEP TJ Front * DANA 44 axle w/locker & chromoly shafts
28950 Views 14 Replies 9 Participants Last post by  scottmcpheert
2
TJ Front * DANA 44 axle w/locker & chromoly $2,499
NEW Jeep TJ Dana 44 Rubicon Axle with Locker!!
NEW NEW NEW, no used or refurbished parts.
Upgrade your 1997 – 2006 Jeep TJ front axle to this Factory BRAND NEW Dana 44 Rubicon axle with Yukon Spartan locker and 4340 hardened inner axle shafts! This is a direct BOLT IN replacement for your Dana 30 in a 1997 – 2006 Jeep TJ.
It comes with the following:
Jeep TJ Rubicon NEW factory housing
YOUR CHOICE of gears ratios from 3.08 – 5.13
Spicer 1310 pinion yoke
Yukon 4340 Chromoly inner axle shafts
Ball joints
This assembly takes advantage of your current knuckles and brakes so NO modification to the brakes or steering components is necessary. Installation is as simple as removing your current axle, transferring over the required components and re-installing the new axle.
We also offer the following options:
Any number of different lockers or Posi traction devices.
Rocksolid Performance axle tube strengthening kit. DOUBLES the tube wall which helps prevent tube distortion under extreme conditions.
4340 Chromoly axle kit, which includes Spicer u-joints, inner axle shafts and outer axle shafts.
Got questions?
Shipping is LTL freight, whatever it costs us is what it costs you!
Buy it Now $2,499
ROCK SOLID PERFORMANCE
Home of the “TRUE-1-TON”
[email protected]
2075 17 Mile Rd NE
Cedar Springs, MI 49319
616-696-8114
We are a custom fabrication shop that specializes in axle assemblies and other related parts for the off-road and street strip market segment. With over 50 years of combined experience and expertise we pride ourselves on innovation, quality and service. If you are looking for a particular part, or are in need of fabrication give us a call!
We can cut and respline your stock shaft for $75 per axle. We also can turn the axles in our lathe, then respline them. All the work is done in our shop.
We are a dealer for all your Yukon shafts, gears, lockers and U-joints.
We stock Yukon 1541 and 4340 blanks for Dana 30's, 44's, 60's, and Ford 9”. Flanged axles can be drilled out to any bolt pattern.
We have drive flange kits for your Dana 60, 30 or 35 spline with steel cover or our machined aluminum covers
Our specialty is custom built axles. We have the ability to narrow or widen a housing based on your needs. We have a line of Dana 44 and Dana 60 axles designed to be a direct bolt in replacement for the Jeep TJ and JK series.​
1 - 15 of 15 Posts
2
Another set out the door!
Our latest set of axles ready for the customer! These were built for his CJ.
DANA 44 Front
4:10 Gears
Yukon Grizzly Locker
4340 Inners and Outers
New bearings and seals
New Calipers and Rotors
New Lockouts
Dana 60 Rear
4:10 Gears
4340 Shafts
New Bearings and Seals
New Calipers And Rotors
Set ready to bolt under his CJ $5,586.00
Nice CJ axles, guys! Were these for someone local, or did you ship 'em off somewhere? CJs hold a special place in my heart!
I can't wait to see how my Dana 60 turns out. I'll check in with you about it next week.
Craig
Quote for front and rear high pinion Dana 60's with TJ brackets to 95901, 64" WMS-WMS, 5.13 RP's, Detroit rear, Eaton e-Locker front, 1350 pinions, 8x6.5 or 5x5.5.
Quote for front and rear Dana 44's with ZJ (TJ front ZJ rear) brackets to 23233, 60-62" WMS-WMS, 4.88 RP's, Detroit rear, Eaton e-Locker (or other selectable ARB, Ox) front
:beer:
Front Axle $ 4,890.00
Ford High Pinion Dana 60 Housing narrowed to 64”
Warn lockouts
’99 Ford Unibearings
Your choice 8x6.5 or 5x5.5
Ford ¾ ton brakes
Stock steering arms
New Ball Joints
5.13 R&P
Eaton Locker
Stock Shafts
TJ Brackets
1350 Yokes
Rear Axle $3,773.00
Flanged 8 lug 4115 axle shafts
Ford ¾ ton Brakes
Detroit Locker
5.13 R&P
TJ Brackets
1350 Yokes
Shipping will be $300.00
This set as quoted Shipped to ZIP 95901 $8,963.00
I priced this out with 8x6.5 lug pattern; we can build the same axle with 5x5.5 for the same price.
You can save $300.00 by changing the E-locker to a Detroit.
Using the Yukon Grizzly locker Front and Rear can save you another $200.00
Thanks for the interest. Please call with any other questions. Looking forward to working with you.
:beer:
Front Axle $2,752.79
Same axle as the top of this thread with Detroit locker and 4.88 gears. This axle uses your knuckles, outer shafts and brakes.
We can include 4130 outers for an additional $220.00
Rear Axle $3,150.00
Dana 44 High Pinion Narrowed to 62”
Detroit Locker w/4.88 R&P
Chevy disc brakes
TJ/ZJ brackets
This set as quoted shipped to ZIP 23233 $6,202.79
Thanks for the interest. Please call with any other questions 616-696-8114
Quote
How much for an hp 30 with 4.88's, ARB, and new balljoints shipped to 89509. Could you give me a 27 spline price and a 30 spline price. Thanks!
Chris
Thanks for the interest in our axles. I priced out a few different options for you below.
HP Dana 30 w/ARB, 4.88 R&P, new balljoints and stock shafts. $1,995.00
HP Dana 30 w/ARB, 4.88 R&P, new balljoints, Chromoly inner and outer shafts. $2,620.00
HP Dana 30 w/ARB, 4.88 R&P, new balljoints, Chromoly inner shafts, and 30 spline hub kit. $3,750
NEW Rubicon 44 as listed in our thread w/ ARB installed $3,075.00
Please give our Rubicon axle a good look. I believe this might be the best option for you for the price.
We can ship any of these axles to you in Reno for $300.00.
Looking forward to hearing back from you. Please call 616-696-8114 if you have any other questions. Thanks.
Hi,
can you give me price on rear LP Dana 60, 64wms, 35 spline axles, disc brakes with parking brake, 8x6,5, can be SF, detroit (arb as a option), no brackets, 1310 yoke
thanks
Hi,
thanks
LP Semi-Float Dana 60, Narrowed, 35 spline, 8x6.5, Detroit, your choice R&P, w/E-brake, new rotors and calipers.
$3,205.00 shipped
Add $400.00 for an ARB
Deduct $100 for a Grizzly Locker
We are currently out of the Rubicon Axle housings. There is a national back order on these. We are on the List.
1979 FORD dana 60 front ox locker shipped to 95076 I'm running 4:88 gears
BUMP for an AWESOME SHOP
I just installed my new Dana 60's from Rocksolid Performance - WOW. This was one of the easiet and cleanest installs yet - complete down to the brass washers for the banjo bolts. Support was awesome and they ALWAYS answer the phone. I tried a local shop (dont want to name any names (4x4land in Topeka) first and the owner said he'd "set me up" and I never heard from him again. Shipping was only a couple hundred bucks on these monsters, so why not get the service and products that a guy deserves. If you're on the fence to buy from these guys DON'T BE - THEY WILL TAKE CARE OF YOU!
@ Robert - i will be in touch soon to get those TJ brackets for my old D44 and control arms that we spoke of. Thanks for all your help...
Joe in KC.
Our latest set of axles ready for the costumer! These were built for his CJ.
DANA 44 Front
4:10 Gears
New Lockouts
Dana 60 Rear
4:10 Gears
4340 Shafts
Nice axles bump for a local vendor change the o and u on costumer unless you guys got a new set coming out for halloween:flipoff2:
DANA 44 Front
4:10 Gears
New Lockouts
Dana 60 Rear
4:10 Gears
4340 Shafts
Does this set still exist? obviously the price has probably changed.
1 - 15 of 15 Posts
