1 - 1 of 1 Posts
Some reasons to buy from www.TrickTools.com: We have an excellent reputation with a whole crew of fabricating experts that provide exceptional customer service and technical support on a daily basis. Any application questions, warranty issues, replacement parts or problems of any kind are dealt with by us. We will work with the manufacturer to take care of you. When you order a deluxe bender kit, mention "Pirate" and you will receive your choice of a free pint of paste lube or $20.00 off of our Bend Tech Tube Bending Layout Software.
The JMR Series of tube benders are precision machined units that offer large capacities.
.....................$1,295
Air/Hyd Features (model 1005)
Unique Air Return on the cylinder
Billet Dies available in 120 and 240 degrees
Aluminum bronze bushings at pivot points
Black coated finish
Built for industrial use and yet affordable
Lifetime guarantee against breakage on dies
Lifetime replacement on US Made Hydraulic pump
Ships UPS!
Specifications
Will bend .250 wall 4130 Tube
Follower blocks case hardened .050 min
All pins made from heat treated 4140
2-1/2" Round Tube, 2" Square Tube, 2" Sch 40 Pipe Capacity
This pump utilizes your shop air supply for power and is activated by a foot control
Approximate Air Consumption - 12-20 cfm
Required Air Pressure- 40-120 psi
1:100 Air PSI to Hydraulic PSI Ratio (i.e. 40 psi of air produces 4000 lbs of Hydraulic pressure)
If you have any questions, need technical assistance or would like to place an order, please reply to this message or give me a call.
Shane Henderson
1-877-826-7268 x106
[email protected]
1 - 1 of 1 Posts
