1 - 4 of 4 Posts
***NEW*** Fox 2.5 Performance Series Coilover Remote Reservoir Shocks
PM ME FOR SPECIAL PACKAGE DEAL PRICING WITH SHOCKS & SPRINGS!!!!
PRICING STARTS @ $427.46 EACH !!!
CLICK HERE FOR MORE INFO OR TO BUY ONLINE!!!!
Description:
Offroad Performance Series coil-over shocks take advantage of our tried-and-true coil-over design and incorporates features found in the entire Performance Series line like braided stainless hoses with high-flow fittings for maximum durability and performance. Locking spring preload rings allow easy ride height and preload adjustment and retain the top quality racing coil selected to deliver your optimal spring rate. Our Offroad Performance Series coil-over shock will suspend your vehicles weight and provide our race-proven, performance damping technology to tame the toughest terrain. If you are looking for a comfortable ride and predictable offroad handling, look no further.
Features:
-BODY - Smooth bore and honed seamless alloy bodies
-BODY PLATING - Zinc-plated for a long-lasting finish
-COMPONENTS - Black-anodized, CNC-machined 6061-T6 billet aluminum
-VALVING - Tunable velocity-sensitive deburred valve shims
-SEALS - Redundant sealing pack system, main seal, wiper seal, scraper seal
-OIL - JM92 Advanced Suspension Fluid for improved performance at variable temperatures
-BEARINGS - PTFE-lined, heat-treated, alloy steel spherical
-SHAFT - 7/8 inch hard-chrome plated heat-treated alloy steel
-ADJUSTMENTS - Spring preload ring, Dual stage crossover ring, Nitrogen pressure, Compression valving, Rebound valving, Optional CD Adjuster
Part # = FOX-983-02-101, Travel = 6.00", Collapsed Length = 10.440", Extended length = 19.45"
Part # = FOX-983-02-102, Travel = 8.00", Collapsed Length = 16.440", Extended length = 24.45"
Part # = FOX-983-02-103, Travel = 10.00", Collapsed Length = 18.440", Extended length = 28.45"
Part # = FOX-983-02-104, Travel = 12.00", Collapsed Length = 20.440", Extended length = 32.45"
Part # = FOX-983-02-105, Travel = 14.00", Collapsed Length = 23.440", Extended length = 37.45"
Part # = FOX-983-02-106, Travel = 16.00", Collapsed Length = 25.440", Extended length = 41.45"
Part # = FOX-983-02-107, Travel = 18.00", Collapsed Length = 27.440", Extended length = 45.45"
1 - 4 of 4 Posts
