Now THAT is some great advice. Please expand on the duty cycle part. Outside the welder being hot, what else do I look/listen for?
I've figured out.....
- what a bad ground acts like
- when the nozzle needs cleaned from splatter
- what it feels like to have a good bead going from a rhythm perspective
What I cant get right yet.....
- There are some welds that I can not get straight for long periods.
Make sure your mask is clean and the correct shade. You probably want a 9, a this is a low power welding operation. If you can't see, you can't weld. Try marking the weld joint with a white chalk before you strike an arc. This will help you see where your going.
- I cant quite get my stick out/nozzle quite right. Meaning....the wire tends to get clogged inside my nozzle from time to time. This seems to happen more often on when welding horizontally. Like when I was welding my flat iron to my angle iron.
Maybe try some nozzle dip. It will help with keeping it cleaner, and cleaning.
Always tighten your contact tip with a wrench our pliers. Finger right will cause weld issues.
- There are times, when I know its not welding "Just right" but cant stop and reassess.
Drive roller pressure and the position of the whip/torch can really screw.with weld quality. The straighter you can keep the whip the happier it will be.
- Still learning the best viewing angle to insure straight solid welds.
In any case, I am happy with my results so far. Its a process and I have never been afraid to learn and try things.
Thanks for all the input so far.
