1 - 4 of 4 Posts
I did a search today on master cylinder upgrades. I installed the MS from a 78 Mercury Marquis. I needed to install a couple of washers so the clip that holds the lid on the master cylinder could clear the booster.
What bothers me is I read on another post that there is supposed to be a seal between the master cylinder and booster? If so, I screwed that seal up when I installed the washers.
Can someone confirm that the master cylinder needs to be tight to the booster for the brakes to work correctly?
I never would have thought of that
You guys are awesome. I never would have thought about going for a test drive. I am so glad I asked. :rolleyes:
I did drive it and it stops better than before but I cant lock them up (only running 31's right now). I was hoping the seal would make the difference.
1 - 4 of 4 Posts
