Newbie here!! Been readin your site here for several weeks, damn yall crack me up
I did search first, but no luck!
A little info on my Sammi first..
88
Weber carb, flowmaster header, 2" exh, 5" Calmini SR lift, 32x11.5 MT's, 1.25" wheel spacers, 5.13 r+p's, lincoln locked in the rear, detroit up front, 97 Sunfire seats
Before the bashing begins on the Calmini purchase , the Zuk is my daily driver and only vehicle, I didn't have access to a shop\welder to do a SOA, sure wish I could have though
Now to my question:
when I switched out axles (thanks Krawwler), the new axle only had 1 brake line feeding it and my original setup had 2 lines...we worked around that no problem but to do so we had to plug the bleeder on the RH side with a bolt instead of a bleeder screw, when I tried putting a bleeder screw in there, there was not enough room for it to screw in.
Do they make a bleeder screw that doesn't go in quite so far, or do I need to take the parts off my old axle and move into the new axle.
88
Now to my question:
