1 - 4 of 4 Posts
quick question, what recommended tank size should i pick up from my welding shop for tuning my air shocks? is the small 21cf enough? or just go bigger?
I like the 60cf tanks. Small enough to carry around but big enough to last a while and they also reduce your gas costs a bit
Most of the guys here have a 20 for occasional use. I did a 40 since it was the bigger diameter to fit in the same mounts that my CO2 tanks fit in too. The cost difference between a 20 to a 40 was only a couple dollars. If you are doing them frequently I would look into bigger.
Discussion Starter #4
Thanks guys! If central has a 60 ill get that. If not 40cf it is!
1 - 4 of 4 Posts
