1 - 4 of 4 Posts
For the past week or so, my left blinkerwould not flash, but it would still make the clicking noise. Then, last night, someone pointed out to me that my brake lights were out as well. I dont kno if this was the first night they were out or if this was the first person who finally stepped forward and siad something. Im heading out to the truck right now to start looking over fuses and light bulbs. Im also gonna check for a brake light switch problem too. Anyone else ever have anything this happen to them or have any ideas? TIA
-Greg
Sounds like a broken wire in the column at the switch itself. First check the fuse, then see if you have power at the white wire going up the column when you press the brake pedal down. You then should have power going to the green and yellow wires in the same connector. If not ---switch. Yellow is left and green is right.
1 - 4 of 4 Posts
