1 - 2 of 2 Posts
So I built a truck out of three the body is a 66 international crew cab the chassis and axles are 2005 dodge 3500 the engine Trans the case harness dash are 2006 dodge 3500 Cummins
The frame and axles were from a Cummins truck too
I have every thing in and working if I clear my codes the s pedometer reads about 1/2 eat it should then starts working properly then nothing the check engine light comes on and the abs light also it has trouble shifting to 4high but if I select 4 low there is no problem and it will go back to high but not directly to high. When it is coding it will not shift the tcase.
I have replaced the transmission vss and the rear diff vss with 2006 model ones with no change
any ideas of where to look now would be appreciated
1 - 2 of 2 Posts
