1 - 20 of 41 Posts
ZUK Herder
Ever hate reading the classifieds because everything is on the other side of the country? Well here is your answer. This thread will be for posting a link to your for sale ads. Put a link to your for sale items in this thread with a short description of what it is. This is not the for sale forum but provides direct links to your items for sale there. Vendors are welcome to use this as well. All for sale threads not in this post will be deleted!!
NOTE: ALL!!!! I sent the better half of the day, deleting post that were either sold, old craigslist ads, or replies to posts! (4000 posts)
***Please to keep this thread active lets do housekeeping on our posts
Delete when sold and edit your for sale posts no bumps **
Buyers do not reply to posts, please PM the seller
.... as of now i will be deleting all post over 2 years old
thank you all for helping!
2 300s and new bushwacker jk FF 205
1 short tail dana 300 $250
1 long tail dana 300 $250
JB twin stick $100
New JK 2 door bushwacker flat flares $400
Ford np205 $150
Located in dubois, PA
Pm your number I'll get back to u
WILL ALSO PART OUT IF A PART IS NEEDED....
Looking to move on from a current project that I do not have time to finish. There is a ton of money wrapped up in this truck. A list of the current mods are as follows:
-357 Cu in engine (Cam, heads, intake) (350 bored 40 over with 6" rods)
-Manual Valve Body TH700 Trans with Art Carr reverse pattern shifter
-Custom Dash with all new gauges (all wiring done with weatherpack connectors)
-Custom wiring harness with stand alone fuse boxes
-Narrowed front end and tail
-Off Road Unlimited Solid axle swap kit
-Off Road Design Shackle flip kit
-Full boat sides using all 1/4 wall material
-Plated B pillars
-Removable Steering wheel with PCS aluminum steering shaft
-Hydro Assist Steering with all PSC components
-Corbeau Seats w/ full harnesses
-Ford Dana 44 front axle w/ lockright locker and custom cromoly shafts (Ford inner with all GM outer including brakes)
-GM 14 bolt semi float rear with detroit locker and disc brakes setup with a single trackbar with heims
-Currently has a NP241 with SYE
-Brand new rebuilt 205/Box4Rox doubler including NWF triple sticks (not installed)
-Like new 36" Iroks on simlock wheels (includes spare)
-Oasis on board air compressor
-Full Roll cage tied into frame
-10K Winch TMAXX Integral Solenoid
-LED front lights and rock lights
Truck definitely needs some time spent on it to finish. There is more than enough work already done that a few weekends of work will have you ready to wheel. We just had a baby and I hate to see this go, but if someone wants a damn good foundation this is the rig for you
Looking to get $6500, Will help with delivery!!!
Text me for more info 570-772-3812
WTB 37x12.5r15 tires with decent tread, located in south jersey let me know if you have anything. Not many companies make this size anymore
I have a 94 Toyota 22RE complete oil pan to intake plus. Ran perfect when I pulled it the beginning of the year. Rebuilt a few years back with a EB full rebuild. Engine is complete with full harness and ecm, all accessories and sensors but PS pump, 4xinovations motor mounts and frame mounts, clutch, flywheel and bell if you want it. I literally unhooked the harness and fuel lines and pulled the entire thing out. Also included is a spare AFM and ECM.
$$550 OBO located 18088 near Allentown. Have a picker here and can load it in your truck for you. Trades considered
Set of narrowed Dana 60 axles.
Description and what's included in picture.
I also have brand new set of Yukon locking hubs and 35 spline outters.
Asking 1500 for all but y'all know better then me so make a reasonable offer.
O and I do not have then yet but should soon.
Arb air locker and 513 gears for the rear. These would obvisouly be extra. I'll update when I have them.
Just PM me I check back often.
Sent from my SM-N950U using Tapatalk
Bump looking to make room in shop move these quick..
Make offer.
Canceled the lockers.
Axles- OBO just looking to make room.
Also have these brand new and never opened parts.
I have 2 sets of 35 spline outters shafts.
$100 each shipped.
And 2 sets of 35 spline locking hubs.
$300 each shipped obo.
And 1 dana 60 gear set..
$225 shipped.
I parted out a 2000 XJ
I have all parts you may need to do a manual trans swap excluding driveshafts & crossmember. Trans, t-case, flywheel, clutch, pressure plate, hydraulics, PCM, pedal assembly, shifter, shifter boot, etc. you may need to do the swap, just ask. I want them out of my shed.
The XJ had like 160k miles before I parted it out.
NV3550/NP231
$450
LPD30
$100
C8.25”
$100
Coil pack rail
$20
Engine wiring harness
$100
I have a lot of other small misc items from the part out. Just ask me via PM and I’ll let you know if I have it.
All are “or best offer”
PM me to contact me.
I've got an 03 4.3 V-6 with 4l60e. From a low mileage ZR2 blazer.Computer flashed to run stand alone, stock air box, "Y" pipe with O2 sensors, MSD billet distributor. Adapter from 4l60e to toy 4cly case (advance adapters). Needs ps pump, was removed for another project. 1200 or best offer. Located 18224. Pa.
Still have axles, one yukon gear set and one set of yukon hubs.
Accepting any reasonable offer, looking to move quick. Shoot me a offer in a PM.
Dodge ram Reunel bumper heavy duty (north NJ) $250
**going to Carlsile PA this weekend (july 13-14) for Mopar nats and can bring this bumper.**
Fits 1993-2001 Dodge truck Quality bumper with reverse lights. 1/4" steel construction with 1/2" steel brackets to truck frame.
Rated at 20,000 pounds towing with a 6,000 pound tongue weight. Here is Reunel's website.
https://reunel.com/service/dodge/#rb
WANTED!
Dana 60 4.10 gears
86-97 F-350 stock front leaf spring packs
Trying to gather the parts to get a Dana 60 under my F-250, my KP60 has 3.55s and no springs
bridgeport style 3 axis CNC mill - avon NY
Need to move my mill out of my friends shop. he has a new machine coming in next week and needs the space. mostly want it gone.
3HP spindle 3600 rpm
comes with 8 NMTB 40 tool holders
48" x 16" bed
28" x 15" x 5" X Y Z travel
tight ways and reversal compensation.
dynapath 10 conversational controller
can add a 4th axis.
can load onto your trailer.
585-245-4409
can't upload pics, search rochester craigslist for shizouka.
Located in Mannington WV 26582
38" TSL on 8x6.5 steel spoke wheels. Half tread of better. $650
Winch bumper with prerunner bar and recovery points for 73-79 f150 or 78/9 bronco. $450
Prices are OBO or may trade. Can text pics.
TorkLift 42" hitch extension, with wiring harness. Used a half dozen times, sold camper and I dont need it any more.
Princeton, MA
$400 firm.
ISO: Turn Key Rig:CASH IN HAND
Looking for a CJ, YJ, TJ, on leafs, room for the family, full cage, etc. Ideally stretched, prefer cast iron box, Tons, V8... But, will look at whatever you've got; really trying to stay under 10-12K. No time to build, I ship out 1/2 the year. Feel free to PM or shoot me a txt. Thanks. 207-592-7103
ISO/WANTED, stock STD or Medium duty XJ Leafs
Looking for a set of stock height XJ leafs in good shape. The closer to 04555 the better. Thanks.
1 - 20 of 41 Posts
