21 - 40 of 41 Posts
I have a Ford 8.8 out of a 2002 Ranger FX4. This is a 31 spline heavy duty rear end for the ranger. It has a torsen limited slip, 4.10 gears, and I added disk brakes. Located in Binghamton, NY. I can possibly deliver if you aren't too far. $400
Looking for a boom yoke for a Holmes 440 wrecker. 220, 440, and 480 is all the same. Doesn't need to be perfect, just workable.
Like this
Looking for a set for 37 or bigger tires, would prefer they fit 17 in rims
Have a set of 37 1250 17 on black soft 8 wheels.
4 used and 1 brand new tire/wheel as spare.
5x4.5 bolt pattern.
Tires are ironman all county mt.
Would sell just tires or tires and wheels. Also with or without spare.
Send private message if interested.
In north east pa.
11-16 F350 4.11 R&P w master install kits
I bought these for my 12 SRW, everything is new, still in boxes and original packaging. $1000 + shipping. Do you own research for application. and fitment. Feel free to PM me with any questions. Thanks.
1 YG F10.5-411-37 10.5" FORD 4.11 R&P
1 YG D60R-411R D60 4.11 REV R&P
1 ZK F10.5-D 10.5" FORD '11 & UP
1 ZK D60-SUP SUPER D60 FRONT
First off. It doesn't have a sticker, and it'll never have another. If that doesn't work then I'd stop reading.
2000 Jeep Cherokee "Beautiful Babs" or Barbara if you don't know her well enough.
Lot of miles, and more rust. Babs has been ridden hard and put away wet most of her life. But don't let that fool you she's still ready to go home at 2am after last call.
Lifted about 4". Coils and spacers in the front, add a leafs and shackles to lift her butt.
Grooved 33" BFG mud terrains and fenders trimmed to fit them
eBay special front winch bumper (we can discuss the winch)
Front d30 with lockrite locker
Rear 8.25 welded
Needs....well a lot. But everything works to include the rear wiper. That's right folks an XJ with a working rear wiper. So she's super rare.
All glass is intact, windows go up and down, heater works, ac blows nice and hot. Some bling radio with remote so you don't have to reach 3 inches past the shifter. New radiator.
So again runs great, won't take a sticker. Built this for a cheap truck competition and decided to keep it for a while when my main rig was getting overhauled. Not needed anymore.
$800
Raymond, ME outside of Portland.
Custom Currie 9" HD housing
True Hi9 third member
4.56 ring and pinion gears
35sp Detroit Locker
35 spline Currie alloy shafts
Wildwood disc brakes
un-welded HD Barnes off road truss (upper link mount)
65.5 inch WMS.WMS
5.5 bolt pattern
All hardware included
Sweet setup for a Jeep / Bronco or ????
This sat outside in a bronco project for a while but was never run. Super high dollar setup. (True Hi9 third is $2700 alone so add it all up!)
$3500 cash firm
East Stroudsburg PA 18301 Less
https://www.facebook.com/marketplace/item/2333039956934425/
Jeep Wrangler TJ one-ton project - rust free / KP60 / 14B
**NOT PARTING at this time** Package deal or I take it with me. Prices are what I paid.
RUST FREE 2006 frame and tub (less than 30k orig miles)
Clear title as a 1999 Wrangler TJ sport.
(Was 4.0 auto w/ engine mounts still intact)
Full 1/4" BTF body armor side to side including tailgate
Comp cut rear with cutouts for LED tail lights.
1" daystar poly body mounts
Rock Krawler long arm stretch kit (increased wheelbase_
RK 1/4" bell plan with integrated link brackets
RK solid steel threaded links SOLID and HEAVY!
custom front grill hoop, bumper with winch mount, stinger
Coil spring buckets removed and could be added or go coilover
no drive train, no axles, no top, no roll bar, no interior, NO RUST.
SEE PICTURES!
Its definitely a project but a killer start for a rust free tub / rust free frame / stretched / armored / long armed / LS'd / bad ass TJ.
$3000. for jeep chassis /chassis.
Un-assembled Ford KP Dana 60 / GM 14B
Front 1989 Ford KingPin Dana 60 $500
Narrowed to 67.5” wms-wms
Correct length inner 35 spline shafts
NEW 35 spline Yukon 4340 stubs $162 x 2 $324
Mile Marker 35 spline locking hubs $100+
NEW Reid Racing knuckles $658
NEW Ballistic high steer arms w/studs $260
NEW TMR 3/4 ton brake brackets $150
NEW Yukon spindles $220 x 2 $440
NEW Yukon King pin rebuild kits $111 x 2 $222
NEW BTF HD diff cover w/ integrated truss $395
NEW 35 spline Yukon Grizzly locker $647
NEW Dana HP 5.38 Spicer gears/bearings $275
NEW Spicer u-joints x2 $100
NEW Spicer seals, bearings, etc $100+
Total $4271
Rear 1994 14 Bolt $300
Open 4.10 carrier
Brackets removed, wms 65.5”
NEW Bronze Kingpin bushings $100
Ballistic shave kit w/ diff cover $290
NEW TMR truss w/ pinion guard $260
NEW Ballistic 5.38 shaved ring / pinion $422
(true yukon they appear to use usa std now)
NEW Yukon Grizzly locker $493
NEW G2 gear install kit $162
Total $1927
4271 + 1927 = $6198+
$5000 cash for axles only
$7500 for all OBO
https://www.facebook.com/marketplace/item/1747527172059884/
2002 Golf TDI 5 speed 4 door 160k. Awesome $2k beater or great swap bait. Plymouth NH.
Current daily driver. Runs great, dead nuts reliable. ALH is the best TDI engine evar. Gets 50 mph if you drive like my dad. Check engine light comes on occasionally for an EGR code. Comes on for a day, goes off for weeks. Passes OBD easily.
Exterior is decent, especially at night. Has had some rust, all fixed. Has plenty of minor dents and scratches, but no accidents ever. Original black paint except where I've rattle canned spots.
Interior is fairly ragged but still comfy and fully usable. Rear hatch only opens from the inside latch but I conveniently busted apart the rear trim panel so it's easy to get to. AC and stereo work great.
ABS and brake lights currently on. Needs rear sensors and reluctor rings. Parts included. I may even get around to replacing them.
New alternator, front control arms, front coils within the last 20k. Brakes all around including rear calipers. Parking brake is pretty sticky though. Timing belt was done at the dealer around 100k.
Tires are fair, I will throw in (4) studded snows with *maybe* 5k miles on them. Pretty much still new. Mounted on factory steelies.
So yeah, basically a cheap car ready to drive. Or, a whole drivetrain for swap in a handy carrying case. I just need something bigger. Yours for the low low price of two thousand bucks.
Dana 60 ARB Locker
Dana 60 ARB 35 spline locker 4.10 down. Compact air compressor, all wiring, air line, fittings to install. All the seals were replaced when installed. Ran for 2 years in my 79 Ford 60. Everything you need to install in your axle, and run. Locker is in perfect working order. $500 located in PA 19460
Text 6103049two4six
ISO: 1st gen Tacoma (1996-2004) rear axle with 4.30 and e-locker. Let me know what you’ve got. I will come pick it up
Thanks, Ben
bobbing for fries
Looking for a set of 17x9 steelies. 8 on 6.5. 4.25 to 3.5 backspacing
Edit: Located near Syracuse NY
today
1959 Jeep FC150 project, 2K o.b.o (Ma.)
1959 FC-150 on 2001 ford F250 frame
have a title for both
ford was running unit before i took the cab and bed off 5.4 gas 4wd auto
FC has lot of rust 2000$ open to trades
MA
Heavily modified TJ for sale in PA
Can't link due to profile being new, but have a 1997 Jeep Wrangler for sale, check my profile.
89 S10 parts getter
1989 S10
4.3/700r4 2wd
$2,500.00
Central Square, NY (near Syracuse)
6 1/2 foot box. All original. On 16" Camaro wheels but have original 14" wheels to go with it (2 beauty rings).
Truck runs and drives good. Could use brakes and possibly a battery.
21 - 40 of 41 Posts
