Ok maybe some progress--took a battery I have and powered up the RED wire to the WHITE CONNECTOR and this is what I got:
ignition off--no other wires have power>>>>>>>
ignition on: WHITE CONNECTOR WIRES:::
RED wire with WHITE tracer has power
YELLOW wire has power
BLUE wire has NO power
ignition on: BLACK CONNECTOR WIRES:::
RED with WHITE tracer has power
BLACK wire has no power(this is a ground wire for the guages I believe)
ignition to START: WHITE CONNECTOR WIRES:::
BLUE wire has power
nothing else has power in the start>>>>>>>
so I'm thinking that the RJM HARNESS purple wire, and please correct me if I'm wrong, would connect to the BLUE wire
and that the RJM HARNESS orange wire would connect to the RED/WHITE TRACER wire---
then I'd continue the blue wire with the rjm purple to the solenoid
on one side of the solenoid would a wire would go to the starter(4 ga or better)
then on the other side of the solenoid you'd have a 4ga or better wire from battery and alternator----
again please chime in if you see a problem or see something I'm missing---
BLUE wire has power
