1 - 20 of 43 Posts
Now that iv'e seen here and there
here is my rockwell's shave
left only 8 mm form the bearing clamps and 10 mm from the ring gear
made from 6 mm steel
:D
Looks good. I'm attaching the images since your server took 5 minutes for me to load them on a REALLY fast connection. As a favor to the other users, you may wanna kill your links to the pics so they don't all have to wait 10 minutes for the page to load...
This is the way I'd go if I was going to shave them myself. Everyone who copied the Avalanche plates mentions what a PITA it was, and that they'd have just bought the plates if they did it over. Your style has only 5 plates to shape and weld... and none of them are curved. :D
moveaside said:
Damn that destroy a lot of the argument with Rockwells right there :beer: I'm guessing this doesn't drive down the street so lubrication wasn't a big concern :p
Have you ever seen the inside of a Rock? There is a lot of room left in there. I might be worried if he was putting them on a Cargo Hauler but for anything under 7,000 pouns and not towing much, they are fine.
pcelle- Out of curiousity, how much fluid does it hold now? That might put some people questions to rest.
Discussion Starter #16
that's done
now the ring lincon lock ! no detriots or slopy traccion 9 im running pinon brakes so 1/4 turn cloud be the cliff!!!
oil=> not worried much about it , it's not going to see any roads
it will be towed by
:flipoff2:
damn! Thats badass! it looks like simular things could be done to other axles, ie ford 9" to create some god rock protection. nery nice work :cool2:
Discussion Starter #18
here goes the rig its a starting point, the idea is to create a structure that's an unibody that bolts on to the chasis , and weld's on at some point's
so that when im thru with it i can discard it and buil a complete unibody
looks good man...real nice...
where did you get that tj hood and grille?...i'm gonna build a unibody crawler in about 4 months...i'm gonna use a tj hood and grille...is it glass?...thanks
James
Discussion Starter #20
I copied them out of a TJ
most of the body will be made of f.glass but the tub
next up date !!! engine ford 460 or a cummins turbo diesel ? I have these two options
:smokin:
1 - 20 of 43 Posts
