1 - 20 of 162 Posts
· Trail Tech Fab
Introducing our NP205 rear support kit. After several customer requests for a simple means to support their 205 from the rear of the case, we are now offering a solution. Use this to help prevent your factory adapter from cracking under load, or use this with one of our clockable adapter kits or clocking plates. Mounts OVER the aluminum plate on the rear of your chevy, dodge, or ford 205.
As with all our kits all required hardware is included. The supplied bushing is 2" x 3". There is no need to remove your aluminum cover. Remove one bolt at a time, and replace with the stud/nut combination. Weld up the tabs in the desired rotation for your application.:cool2: Price is $70 shipped to your door. Send us your email address and we will send you a PayPal invoice. We typically respond within the day.
Need a better pic here.....
Customer installed pic
Pic of PTO mount Kit
Hit us up with any questions. Thanks,
Mike
Trail Tech Fab
· Trail Tech Fab
We can do a PTO cover kit for the 205 for the same price of $65 shipped. This would be made from 1/4" plate(3/8" on the tabs), and include a gasket, bolts, bushing components, etc.
Thanks,
Mike
1 - 20 of 162 Posts
