1 - 17 of 17 Posts
Are there geras for a NP p208
I need a 2:1 low ratio for tcase
or 1:5 ratio would be even better
are there any swaps ...for the gears in this case
Are there any other tcases with a 1:5 ratio out there ?
I know AA has developed a 2:1 left hand side drop for the atlas
this is my best option ...but are there any 1:5 ??
THX
I am pretty sure (99.999999%) the NP208 that I had in my old (highschool days) '82 GMC pickup had 2.72 gears in it. The little tag on the t-case will indicate this.
edited to correct year
According to the tech specs on CK5, all 208's were 2.61:1 ad the 241's were 2.72:1... *shrug* And they didn't start putting the 241's in until around 88/89...
I am wondering if this guy had a typographical error and wants 4:1 and not 2:1... If thats the case, pull the 208 and use an NP 203 range box mated to an NP205 with an ORD(or similar) doubler adapter.
my 208 has 2:61 ratio ......sorry
I need 1:5 ratio .....
this is for a whipple blown crate 502 on a Sand Nissan Patrol
I need at least 60 mph on low
my final gear ratio today is 11.07 to high
i need at least 6.5 .....
Discussion Starter · #11 ·
ok here goes the full specs
94 Nissan Patrol 4 door
whipple 502
Th400
Np 208
std axels ( axels 4:11 )
there are only 4:66 and 4:88 gears for the axels ......
how about this set up
Th 400
Ranger splitter ( 27% overdrive)
Atlas 2:1
would give the 1:5 I need .........wolud the range splitter hold ?
What size tires? A true 35" tire, with 4.10s and a 1.96 low, will put you at 4631 rpm at 60 (plus converter slippage).
FYI if you run 208 in low and rap out the motor in OD the planetaries get really loud. :D
And ditto on what Old Scout said.
And Cory, I'm even more sure you're wrong, than you're sure you're right. 208s were 2.61. :flipoff2:
Pete
Discussion Starter · #16 ·
Pete
Tires are 31 x 12.5 fun country front and paddel rear same size
any bigger would snap the axels ....( nissan rear 1.3 inches thick 33 spl , very similar to d60 )
how about a overdrive between the th400 and the trans ?
1 - 17 of 17 Posts
