1 - 6 of 6 Posts
I have a 76 cj5 with a mopar EFI 360 and 727. I'm going to put a NP 435 out of a 77 dodge truck with a jeep dana 300. Looking for any info on a hydraulic clutch set up. I would prefere a hydraulic throw out bearing. I've burned up my last auto, I'm going manual.
Its not an easy fix when you blow one of the o rings in the hydraulic throwout bearing, especially when your on the trail, its better to go with an outside slave cyl at least they are easier to fix. i have lost three hydraulic bearings on mine i am changing over good luck
hey 87jeepwrangler, do wranglers have hydraulic clutches origionaly? did you use that slave cylinder, or did you use the ford setup. If so what applications should I be lookiing for. I'm also curios if the dodge clutch fork is different, (ratios) than ford or chevy. I'll be pulling it out soon to do some measuring.
as otto man said, yes, some jeeps do have hydraulic cluthes. although i did re-use my clutch master cylinder, i used the chevy slave cylinder which went along with the 86' chevy external slave bell housing. sorry, but i dont know anything about the dodge's ratios, forks, etc. the chevy-jeep stuff just simply swapped directly. if you wanna see pics and a short write-up, check my website under the projects section.
1 - 6 of 6 Posts
