Here is some tech I thought I might share with you guys. Upon searching many hours on PBB myself and Cajun4x4 decided to tear apart his big bearing round pattern 205 to swap in some goodies.
The reason we are swapping the long 32 Spline input gear to a short 32 Spline input gear is due to the Long 4.5" stickout on the back of the TH400 we are mating this tcase to. The long input on a 205 is made for a 2.5" stickout on a TH400 Hence us buying a short 32 spline input from a racetrack 205 which uses a 4.5" stickout tranny a 4"ish adapter and a short input. Thanks to Grumpyold Fart's thread we realized we could just swap input gears and be on our merry way. While doing that we decided to upgrade the stock GM 30 spline front output with a 32 spline front output and changed all 3 seals. Here is our attempt at a tech article for your viewing pleasure.
first the twin stick shifters where removed
next the th400/6 bolt round adapter was removed
remove the rear output yoke using a 1-5/16 or 33mm socket
using a 9/16 or 14mm socket the rear bearing retainer is the next to come off
remove the rear output bearing
then the speedo gear
