Just need the planetaries...
orangefj45 said:i wish. these parts came out of a case that cracked due to the front driveline being too long. both halves were junk, but i do have most of the guts (had just been rebuilt) and the 2 extension housings.
internally, both cases should be the same, except for the shifter setup, the fluid pump and possibly the shift forks. the case halves and intermediate extension housings are different for sure, and the rear ext housing mught be different as well.
i think it would be way easier to just find a complete proper case.
Colorock,colorockxj said:Not tryin to hi-jack, but Krylon, I have a 241d pass drop with a factory fixed yoke that I took the planetaries out of for my 231. PM me if you are interested.
Make sure the gear pitch is correct if swapping input gears, they changed them around 95.
Would you be willing to throw in the shifter fork assembly? I'm thinking maybe I'll need to swap them also.orangefj45 said:i wish. these parts came out of a case that cracked due to the front driveline being too long. both halves were junk, but i do have most of the guts (had just been rebuilt) and the 2 extension housings.
sure.Hammerlock said:Would you be willing to throw in the shifter fork assembly? I'm thinking maybe I'll need to swap them also.
A 1992 planetary is perfect. Paypal imminent.orangefj45 said:27 spline input gear
paypal @ [email protected]
i can ship it today and will get back to you with a UPS tracking #. shipping should be $12
