1 - 6 of 6 Posts
Hey guys. So my issue is with my 91 k1500. It has the floor shift np241 tcase and it is stuck in 4wd. I replaced the fuse after thinking the actuator might be bad and I gained 4wd.
Well I did some light wheeling in it and it didn't like coming out of 4wd. I tried shifting from 4hi to 2hi in neutral, park, drive. Tried shifting from 4lo to 2 hi in neutral. Nothing happened. Then I tried restarting the truck. After awhile I just took out the front driveshaft to make it home.
Does anyone know why it might be doing this ? Low range works for sure as I've used it in 2wd low range with the front driveshaft out to test the case.
Thanks in advance !
1 - 6 of 6 Posts
