1 - 3 of 3 Posts
OK Last week i had my NP435 oil changed. I couldn't do it because i couldn't get the damn drain plug loose and i stripped it trying. So i took it to a shop and the guy got the plug out and fixed the plug for me.
He filled it from where the shifter is. He used my 75w90 Redline oil i had. The problem i am having now is its grinding 2nd gear if i try to downshift at all. It only does this if i've driven it for a while and i am wondering if he accidently hit one of the sliders inside out of position before installing the shifter would that cause it to grind? It never has done this before and i have used Redline before as well.
Thanks,
Cobra
I doubt it is related to what he did.
the stick pushes on rails IIRC
nothing near a syncro
try matching rpm when downshifting to make the rebuilt box last longer
drain and refill with 85w140 and forget about it till the bearings are toasted. your syncro is getting worn out.
1 - 3 of 3 Posts
