Ok, I need to replace the front bearing retainer on a np435 that I'm putting in my bronco, when I removed the old one I noticed that it had 5 or 6 paper gaskets, searching around I found that they are used to shim it for proper end play. The problem is I don't know what the proper end play numbers are, anybody know or have a link to a manual? Anybody know if one of the small parts/seal kits will have enough gaskets? I'm assuming that I can't just use the same amount it had, or can I?
Brewchief
Brewchief
