My oil idiot light comes on when at idle and then it goes off when on the throttle,I checked oil level and is right on since i just changed the oil this past weekend and the pressuare is also fine, 20lbs at idle and over 80 when on the gas since i run the LC Pro oil pump.i figured it is a loose connection and i wiggled around the wire to the sender with no luck ,could it be the sensor itself?
