I have converted my 22re timing chain set to the LCE double set-up and I had to detach part of the oil baffle in order for the valve cover to clear the chain set-up.Must i seal it up cause I have a lot of spewing out the breather hole.I once had a K&N type breather and original hook-up to plenum and the oil spews out after normal running operation.Does the baffle need a new gasket or sealing the gaps with JB Weld or something would solve the oil leak?I know that I cannot seal the breather hole.
