<font color="yellow">I'm just about fininshed with my TPI 383 (again). This time I'm putting it together myself, since I can't find a shop to do right and can't afford to have someone do it again.
My question is this. What oil pumps are you guys running and why? I've heard/read that a stock oil pump is fine for volume and pressure up to 6500 RPM. This is a low end motor, it will come apart long before that (5500) and the computer has a built in rev limiter (5200). Also, what is the HP lost to a HV pump vs. a standard pump, I've heard as much as 12HP and as low as 2. I don't care about the 2HP but 12 ponies getting away from me might make the decision easier... I always run high volume/pressure pumps, but is it actually needed and worth the extra cost, and does it out weigh the HP loss??</font c>
