Hey guys. I'm new here. I'm currently in the planning stages of swapping a solid axle into my 2000 blazer ZR2. I already got the axle, it's a Dana 44 from a '77 ford bronco. I have a couple of questions that I'm not too sure of, and I'm hoping you guys will be able to help me out with:
1) Will I lose my front antilock brakes?
2) My friend told me that I don't want the exact same gear ratios in the front and rear. Is this true? I wanted to go with a 4.11 (I'll be running 33" swampers), but if I need the exact same gear ratio, I'll have to go to 4.56 because that's the only size that the D44 and my GM rear axle share in common. If it's ok to use slightly different ratios, I can do a 4.11 for the rear axle, and 4.09 or 4.10 for the front.
3) Is it a good idea to use a detroit tru-trac locker in the front? I'm definitely putting one in the rear axle, but will putting one in front give a rough road ride?? Would I be better off going with a limited slip??
Sorry for the long post and all the question, but I want to do this right the first time and just need to figure these things out. Thanx for any help guys!!!
PS - I'll post some pics of my ride when it's done in the spring!
