1 - 11 of 11 Posts
This type of pump will work but you need to ad an extrenal oiler on the intake among other things, auto pressure cut off switch, pressure relief valve, storage tank and fittings. Or use the older YORK with a crankcase.
Originally posted by TeraTJ:
<STRONG>I was thinking about doing this using my stock a/c on my tj. Will that put out enough psi?</STRONG>
PSI yes though stay out of the Tank Trap with it. Bad for longevity <IMG SRC="smilies/frown.gif" border="0"> And boy are they spendy to replace.
What about using that air pump as a poor-man's forced induction system??? Plumb that sucker into the carb and you're golden!!! <IMG SRC="smilies/thefinger.gif" border="0">
What they said. Welcome Newbie.
<STRONG>I think that i am going to use the york, but just wanted to see if anyone has used the stock a/c on the tj, now i know. Thanks to all. <IMG SRC="smilies/smile.gif" border="0"></STRONG>
Yes I did it. It works fine. You just have to oil it before each trip and after airing up 4 tires. Occassionally during Air tool useage.
I carry a bottle of Sears Airtool oil with me and just squirt some in each time. No problems yet... Unless you count the compressor I seazed up from sandblasting with it. We were using it for about 20 minutes at 3000 rpms when it gave up. Guess that was just a bit too long without oiling it. No problem 75 bucks and i bought another compressor from a junk yard. Back in business and no problems again.
<IMG width=320 height=240 SRC="http://www.pirate4x4.com/ubb/uploads/aircomp.jpg">
<IMG width=320 height=240 SRC="http://www.pirate4x4.com/ubb/uploads/accomp.jpg">
<IMG width=320 height=240 SRC="http://www.pirate4x4.com/ubb/uploads/airman.jpg">
1 - 11 of 11 Posts
