1 - 20 of 34 Posts
OK.. I finnaly installed my ARB up front but my deal on their air compressor fell through. There are many compressors on the market, and dont know enough about them to make my dessision. I need a compressor to run my ARB, fill tires and eventualy (maybe sooner that later) run a tank for air tools. What are you guys running and do you like it?
lots of choices- here's a couple
Air on the cheap- caddy compressor and a small tank
on the 4x4 wire
Power tank or other CO2 source- I use a 20lb MIG tank and regulator for my onboard air. It will fill 25 to 30 tires from trail pressure back to street pressure for about $17.00 to refill the tank. It would be relatively easy to adapt it to an electric or manual valve body for an ARB. The electric valve body could be wired into the ARB on off switch-
later
If you want to run air tools, you've only got a few choices.
Engine-driven A/C compressor.
CO2- (Powertank or your own version of the same)
Oasis (Oa$i$) electric driven York A/C compressor.
I prefer the first choice myself! :D
Go with a York belt-driven, the overall cost is going to be less than a Powertank, takes up a lot less space (since it's not inside the truck), less prone to theft, and it never needs to be refilled. If you add a good-sized tank, you'll be able to run air tools as well as your ARB's.
The electric-driven York sold as the Trailhead is another option, but it's a BEAST, heavy, bulky, and it sucks up a LOT of amps.
zidaro said:
powertank!!! kicks ass, fills fast, lasts forever, light, mobile, independent
I have a CO2 tank but it only last so long and it will be nice to have a compressor onboard. The best thing about the CO2 over the compressor is you can carry it 3-4 trucks in front or behind you to fill tires or run air tools.
aaron t , put a zerk in for lube and not run an oiler :confused: how is that going to work ?
CO2 tank, $93 filled from A1 Fire Extinguisher in Huntsville, AL. Costs $16 to swap for a new filled tank.
Regulator was $40 from welding shop - had a busted low pressure side guage. New guage was already on hand.
Mounting bracket was $25. (ouch, but the exact same thing from Powertank is about $50)
Exhaust clamps were about $2.
So for about $160, I got lots of tire filling air, and my AC still works. Sorta, but that's another issue.
I am running the York Bracket Bud sells for his friend. It is a tight fit and does not leave much belt on the Air conditioning pump, but appears to be working. I have not recharged the system so i don't yet know if the additional load will cause the belt to slip.
you also have to beat the inner fender some on the passenger side to get it to clear.
As far as where to get a york, older Volvos in the junk yard have them. Early 80's. The ones that are under the power steering units are the ones you want (more CFM), even though they are more of a pain to pull... Last one i got was $20.
The only problem is that you have to constantly pay for air when you get the air for free when using a york or ac.
1 - 20 of 34 Posts
