1 - 13 of 13 Posts
I'm putting an onboard air/welder combination on my '76 FJ40 with 2F. I just finished the hard part: Mounting the York compressor. The link shows the pictures on mounting the compressor and it also shows the quick fix for plugging the oil blow-by in York compressors. I plan on mounting a Ford CS130A 130 amp alternator for the welder and plumbing the air tank in the next couple of weeks and I will update the link.
http://members.home.net/cglabe1/Air/Air.html
The oil hole plug is the same modification that SabreForce sells you for $75. It might take 15 minutes to do it, including removing and replacing the seal. I found the modification somewhere on the net, but I can't find it any more or I would have just linked to it. It cuts down on the oil blowing out by about 90%.
Hey Ken,
I am mostly finished making the OEM soft top bows except for some of the brackets and attachment points. I still have to look at an original set that a guy in our club owns and measure them. I figured that with the fabric part costing $500 and winter coming on that I would put it on the back burner until next spring.
Hey Pinhead I'm going to be down in OC next Sunday I would love to check out that compressor set up. How's everything going BTW? I didn't realize that it was you since you changed your sig pic. <IMG SRC="smilies/biggrin.gif" border="0">
[ 09-23-2001: Message edited by: Sloan ]
Discussion Starter · #11 ·
Ken,
I didn't find one in OC. I went up to the Pick N Pull on Blinn Ave up in Wilmington just past the LA river on PCH. I made the mistake of going on 1/2 price weekend and had to walk 2 blocks just to get in. I swear I was the only guy there that spoke English.
1 - 13 of 13 Posts
