1 - 5 of 5 Posts
just picked up a jeep with 44 in rear, for some reason the rear is off to the left by 1-1.5 inch. the guy said it would be stronger with pumkin in line with tcase.
my question is can i put a spacer on the other side with out crazy unforseen engineering issues.
using a wheel spacer WILL NOT move the offset of your axle . 1-2" is nothing really . Don't worry
I think he is saying the the previous owner welded the rear end in offset to the driver side 1-2" so the driveline would be perfectly straight with the t-case.
Just cust the perches off and recenter the rear end.
is the pumpkin off center of the whole axle? or is the axle sticking out one side farther than the other?
if its the second case then yes you can buy a single wheel spacer and run it on one side$$$$ or just cut the perches off and reweld them where it is supposed to be
BTW: if there is alot of mod/fab work on this then sell it b/c the guy who sold it to you sounds like he has lost most of his screws and the rest are loose
1 - 5 of 5 Posts
