1 - 10 of 10 Posts
I was wandering peoples opionion on how much different in flex an performance when you switch to full size axles on a 83 pickup. right now i have newer rear axle and two inch spacers up front. is it worth the work. i am running 5.29s arb up front welded in the rear. the other axles i have are 10 bolt front and rear
If those are your donors--don't waist your time--they are junk.....
wider will give you more leverage on your springs = more flex. if you are breaking axles then yes upgrade, 30 spliners and a diamond housing or a 60. dont waste your time with a 44 or 10 bolt
i am not breaking axles i have birfields in them right now. I was just thinking flex wise
i am just going to keep running my yota axles they havent let me down yet
Change is good.
1 - 10 of 10 Posts
