Did you try since I fixed the links?das_jeepinator said:if you were spelling "404 not found" thats some damn fine welding for a first time :flipoff2:
fix your links and I'm sure everyone will be happy to critique your welding capability everyone can improve it's a more you do it the better you get when welding![]()
Does decreasing the wire speed decrease heat, or will I get more penetration by turning down the wire speed and going slower? Will moving the nozzle closer increase heat also? I didn't want to keep it too close for fear of clogging and grounding the nozzle from all the spatter.florida4x4 said:need more heat and work on consistancy in your weld weave. adjust the feed until the weld sizzles like bacon frying
That makes sense, but will it clog the nozzle easier? You mean to actually touch and drag the nozzle on the workpiece?larryboy said:drag the tip a little it helps shield it a little more.
yes,drag it a little at an angle.after a pass just tap it on the side of what you are working on to knock the buildup out of the nozzle.jrussell said:
Thanks a lot guys, your input has been very helpful!
