ORI Strut Mounts
16526 Views 20 Replies 16 Participants Last post by  Bob Williams
i am expecting a set of ORI's in the next few days but in order to mount them I need some new shock mounts. I am currently running the single piece one that Poly sells (no the 2 separate tabs that you weld). If i am reading this right, the mounting width of the ORI's is 1.60". how are you mounting yours? grind down the mounts or does someone make one that is wide enough?
21 - 21 of 21 Posts
Built the front mounts out of 1/4" plate by hand. They've held up well.
Did the rear axle recently, and got lazy and purchased 1/4" parts and drilled for the 5/8" bolts and welded it all up.
If you can, make your own parts or cusomize off of someone else's. It's more fun and usually works better.
21 - 21 of 21 Posts
