1 - 4 of 4 Posts
going o.k. , found that the A/A adapter is the old style with no spud shaft. Was wondering if it is still just a bolt up or if anyone knows why A/A quit using it and went to the 4.5" with spud shaft ?
I thought they would directly bolt in no matter the situation. If you had an origonal in then it should fit?
On another note has anyone had a problem. I want one just dont want to afford it till I know for sure it is the best route.
Newbie Forever
Mine doesn't have the spud shaft either; old style A/A, but it all went together fine....CRAWLS :smokin: Plan on a run thru Swamp this Sat. then on ta Moab Oct. 23rd-29th.... :D
Tomsryd said:
...CRAWLS :smokin: Plan on a run thru Swamp this Sat...
After your Swamp Lake run, post up here how the Orion/crawl ratio felt in vivid detail so as to induce inappropriate drool. :grinpimp:
Walt<><
1 - 4 of 4 Posts
