1 - 4 of 4 Posts
Hey guys, I recently came back from a long drive from LA to Phoenix. I noticed on my way back that I lost overdrive, and ended up driving back in 3rd the whole time.
The pickup shifts in all the lower gears just fine, without slipping, and the tranny fluid also seems adequete. However, it just seems to refuse transitioning from 3rd to OD.
For a while, before this started, it had been slipping from OD to 3rd on the highway. Like I really had to let go of the gas to keep it in OD. Additionally, i have now notice that when I push the Overdrive button on the shifter, the light on the console does not come on to indicate that OD is off.
I have concluded that what I need to replace is the "overdrive solenoid," whatever that is after reading a few forums and threads posted here,
After checking at my local O'reilleys and looking at eBay and google shopping, I am still not sure what to purchase and from where.
Oreilly's told me to get part number 18-1722 Import Direct Ignition - Transmission Switch ($160)
Link
But I found something similar with a different name on ebay, part Standard Motor Products TCS33 Automatic Transmission Solenoid ($140)
Link
But I also found this thing called a kickdown solenoid on eBay ($320)
Link
And a cheaper one on Google ($240)
Link
Which of these should I be getting? And on top of that, am I even on the right track and replacing the right thing? Under normal circumstances I would certainly purchase both, but they are both a lot more costly than I would have expected.
It is definitely in D.
It will go into third gear just fine. If it was stuck at 2, the transmission would not shift past the second gear, from what I have tried.
Additionally, I have read that the operating temperature may affect whether or not it goes into OD. I have checked the thermostat and other parts of the cooling system and from what I observe, that does not seem to be the issue.
1 - 4 of 4 Posts
