1 - 11 of 11 Posts
Does anyone overfill tranny, t-case, diffs with oil. I'm overfilling my rear diff through the breather hole since I turned the perches up 8 degrees. A friend told me not to overfill the tranny or t-case. What do you guys do?
I wouldnt over fill the tranny or tcase, unless you have a reason to warrent it. Leaks odd mounting etc...
I do 1 of 2 things depending on the tranny or vehicle. 1) run normal grade stuff, figuring it will get contanimated etc. and be changed more often. 2) run a synthetic and change it per manual specs... (or longer depending)
On a side note, after my brother burned up the rear output bearing on his 88 tranny. He switched to 20W50 motor oil during the cold winter months to prevent oil starvation on the top end stuff... The around town <10 miles never gave the gear lube time to warm and flow enough.... I think i read somwhere (here) newer ones have sealed bearings to prevent this issue
anyway....l8r, -yag
Thanks,
Just wondering because of rumors that trannys wear down faster when there is a lack of oil (going uphill during wheeling). But if no one has had problems then that must be a jeep thing.
I can think of better things to worry about... I rank this on my list of to do stuff right after changing the air in my tires and retorquing the lugnuts on my spare tire.....
shigagegarifilous...
:flipoff2:
Be a bit careful overfilling the tranny. I (long ago) took my sammy to a transmission shop. after they rebuilt it they got lazy and (over) filled it though the shifter mounting hole. filled it clear to the brim. Later, going over a rather high mountian pass on the freeway, the front seal let go. Tranny oil all over the cluch...Yuck! I did make it home, it was mostly down hill from there, and they did admit it was their fault and fix it, but the danged thing was just never the same after that :(
Hophead
I actually wondered about the rear diff myself. I notice after my spoa that the fill hole is awfully low compared to the axle centerline
Don't overfill unless you like leaks.
The 8-degrees would be about 0.7 inch based on a 5-inch radius.
To counter this I would back my rig up on a slight slope or jack it up slightly then fill if your really worried about it.
I have never had any rear end problems that weren't abuse/dirt related.
1 - 11 of 11 Posts
