Here are some specs.
1983 Chevy K5 Blazer registered and insured
Featured on the Ultimate Adventure 2009, 2014
1st Place Parker 425 Best In The Desert 2011
KOH Certified Hammer King Banded 4500 class legal
Exterior
• 2012 Chevy pickup front clip
• 2012 Chevy pickup bedsides
• 40” Tilden Motorsports LED light bar
Engine
• Custom built 367ci 550hp LS Engine with Tilden Motorsports Ultra 4 Cam Package
• Balanced and blueprinted
• Full ARP mains & rod bolts
• Tilden Motorsports LSx Pro Series stamp steel oil pan
• Custom AFR CNC machined 210cc heads with 65cc chambers
• Hooker Headers
• Custom Magnaflow Exhaust
• Taylor Performance wires
• Flipped intake
• Tilden Motorsports hi volume oil pump
Drivetrain
• Maximum transmission TH400 with manual valve body, billet input and output, rear lube port for planetary gears, and 300m internals
• 2.75 first gear set
• B&M shifter
• Maximum Transmission 2800 stall converter
• Ron Davis transmission heat exchanger and cvr large cooler
• Ron Davis custom radiator
• ORD NP205/Klune V transfer case 4:1 ratio
• Custom 1350 CV’s front and rear driveshafts
• Currie Rock Jock front axle
• Custom rear axle housing and torq super 14 third member
• 5.13 gears
• ARB locker in front and spool in back
• Yukon gears, axles shafts, and hubs
• Hydro boost
• Dana 60 brakes in front and rear
• Rear brake lockout & proportioning valve that is adjustable on the fly
Chassis
• Sectioned, plated and tubed frame
• Full tube chassis
• Custom valved Bilstein coilovers front and rear
• Custom skid plates
• Hydro Assist steering
• Nitto mud tires 40x17
• Trail Gear beadlocks
• Custom valved, 2.5” Bilstein bypass coilovers front and rear
Interior
• Twisted stich suspension type seats
• Autometer gauges
• Grant steering wheel
• Rugged intercom system
• Lowrance GPS system
• Parker pumpers
