1 - 11 of 11 Posts
HEY NOLEN, I'M SWAPPING THE PINION FLANGES ON THE DIFF YOU SOLD ME. DO YOU HAPPEN TO KNOW WHAT I SHOULD TORQUE THE NUT TO TO GET PROPER PRELOAD?
THANKS, MATT
OPEN TO OTHERS TOO
Ideally there is a torque setting, I don't have a manual here. I use an impact, and bump it kind of like I would a lug nut, someone should have the spec handy.
Too tight and you will mess up the backlash if you have a crush sleeve, if it is too loose you will be able to pull it back and forth it will have "play"
Butch
NO CRUSH SLEEVE, THE CARRIER IS FROM A 77 SO ITS SHIMS.... DOES THAT MEAN I CAN WAIL ON IT WITH THE IMPACT FOR A SECOND AND CALL HER GOOD?
RIGHT ON! GEEZ, I MIGHT HAVE TO START HATING TEXANS LESS ;)
DID YOU GET THAT SECOND EMAIL?
That's OK we native Texicans know it's just jealousy
:flipoff2: :flipoff2:
Yes got it, have not located the spring pins, post it here someone has to have some. Seat brackets I don't have either.
Butch
Discussion Starter · #9 ·
I ACCTUALLY FOUND THE SEAT BRACKETS! FOR ONCE I ACCUALLY found A PART I LOST. GUESS I'LL BUMP THAT THREAD UP. BUT YOUR GONNA SEND ME A WASHER? :D
PSHHHH. JEALOUSY? IF YOU HAVE TO TELL YOURSELF THAT :shaking: :flipoff2:
1 - 11 of 11 Posts
