1 - 3 of 3 Posts
Hi, I have a 1985 Toyota 4x4 Truck. I just noticed if I have the parking brake on and i rock the truck back and forth, the back brakes make a noise. Its like a urrg, urrg noise. And also when my parking brake is pulled all the way my trucks tires still move. My parking brake is weak. I wanted to know if this noise is from the parking brake being weak and the brakes not griping enough. The noise is only when i pull the parking brake, if I have the parking brake off the truck will rock but it doesnt have the noise. PLease Give me some Info!!!!!!!!
are your drum brakes worn out? <IMG SRC="smilies/biggrin.gif" border="0">
i took my rear breaks apart and found that the "automatic" adjuster had been disconnected so i hooked it back up and adjusted to where the pads held the truck again. <IMG SRC="smilies/glasses.gif" border="0"> holds just fine on a steep hill out of gear! <IMG SRC="smilies/massey.gif" border="0">
The rear brakes in the solid axle trucks really are pretty lousy. My parking brake would never stay in adjustment. Your best move is to find an '86+ rear axle and swap this in. The axle is wider, the drums are a lot larger, and the internals for the brakes are much better.
Or you could get an AllPro t-case disk e-brake.
I just did both. The AllPro e-brake works very well.
BTW, if you want any rear brake parts for your existing axle, I give you the stuff I have for the cost of postage. I also have my entire '84 rear axle complete I'm trying to get rid of.
1 - 3 of 3 Posts
