1 - 9 of 9 Posts
I want to cut off the air input to the box from behind the headlight, not 100 % sure what the ceramic part is mounted on the fender by the air box?? its broke in 2 ??what is it for?? can i move it??, I am going to cut a 4" hole on the backside of the box to get some air.
That's your ballast resistor for your fuel pump. Supposed to buffer things a bit and keepp it from coming on and off too much. You can by pass it by connecting the two wires. Does it run now? If so, someone already bypassed it would seem.
That resistor is there to reduce pump RPM, in an attempt to reduce pump noise.
It can be bypassed without harm, other than a noisy pump.
well, I was close:p RPM makes sense with a resistor. Regardless, not needed and can go.
I'm planning on pulling my air from the firewall vents at the windshield wipers myself.
1 - 9 of 9 Posts
