1 - 9 of 9 Posts
Originally posted by BIGBIRD:
<STRONG>sounds like you need to bleed your system, start it up, turn the wheel all the way to the right, and hold it for approx 5 sec. then go to the left. then right . left. check fluid level.. use atf</STRONG>
i did that 2 times befor i drove it i will try again.what is atf auto transmition fluid?is that better than ps fluid?
1 - 9 of 9 Posts
