1 - 20 of 28 Posts
Rolling Mod
I am looking for ideas on how best to add airbumps to a 96 F-150 4WD while keeping the stock coil and shock arrangements. I have seen many kits with custom coilbuckets and the shock relocated in front of the spring. Has anyone seen a truck with the coil and spring in the stock location that has airbumps. I have damn near worn out the internet searching.
Thanks.
any chance to putting the bump on the backside of the bucket, striking the trailing arm?
is there room for an a-arm type?
is there room on the inside of the frame?
im having a hard time finding 4wd and all the 2wds have coilovers
On a quad shock front, there is a bracket on the front of the beams for a shock mount...
I would look into mounting the bump in front o the coil, and build a strike plate to work in that area....
In fact, I am pretty sure I have seen that set-up....
Chase
X2 go inside of the coil bucket, but making a striker on the bolt that the radius uses to bolt to the beam might be a little tricky.
It MIGHT work, BUT, it would be less work, and cheaper to mount a cup on the frame, and build a striker...
Or, mount the cup, on the frame, in line with the coil, where the rubber bump stop is, and use the beam as a strike...If needed, add some plate for a little strength...
Chase
Rolling Mod
That is the problem I found. Almost everything with bumps has coilovers, at the very least they have moved the shock to the front.
Inside the frame would be a challenge to get great all over welding without pulling the motor.
Chase
This is kind of what I am thinking too. I was looking to see how this had been done in the past.
In the distant future we will coilover the truck. At that point it will be fairly easy to add bumps. In the meantime I would like to dampen the huge hits.
any chance of running a single bypass heavyily valved with liberal use of the bypass giving you some stiff valving on the last bit of travel? not really the proper way but will give you what youre looking for.
why you looking to keep the coil bucket? shop truck?
Rolling Mod
Discussion Starter · #12 ·
Yeah this is the shop truck. Trying to use products were currently manufacture. Next year we will make some improvements. We put bumps on the back and I am very happy with them. Looking for ideas for the front.
I accidently took a big jump in Barstow. The rear took it the front was a pinch harsh. If I get the video I will post it up. Trying to figure out if I can easily improve the truck before it goes to Pismo in three weeks.
Currently it has gone for the Expo. Hopefully I can find some F-150's there for ideas.
you running a stock front suspension? cause the few pics of stock suspensions ive found, you dont have room for much inthere.
what about mouting the bump unpside down on the trailing arm and having it strike the frame?
Rolling Mod
Discussion Starter · #14 ·
Whoops, I meant to post these as well.
The pics aren't the best for what you're after, but it's back there. I was somewhat surprised at how they're made, but the truck has been in hard use for a few years now and aside from the marks the bump striker makes, they look new. Rick (the owner) frequents Pismo if you ever want to see it in person. We're planning a camping trip at the beginning of the year if you're interested.
1 - 20 of 28 Posts
