1 - 9 of 9 Posts
<IMG width=550 height=366 SRC="http://www.pirate4x4.com/ubb/uploads/chris_h_rock_06.jpg">
Originally posted by Jared:
<STRONG>Nice Jeep. What size tires are those? And if those are 35's, did you open up the rear flares any?
Jared <IMG SRC="smilies/smokin.gif" border="0"></STRONG>
Jared
They are 33x12.50's I have not opened up the rear yet but am going to do it I have tj flairs to match the front just haven't had time yet they do rub at full flex Hoping to change that with the sawsall
The fron has a shitload of metal cut out for the flairs I mounted them at the seam on top and cut all the way up to the bottom of the flair
Not a bad xj. I got a 99 with 9in lift and extras! I have 33's but will be going to 38's <IMG SRC="smilies/biggrin.gif" border="0"> !! The fenders had some major surgery done to them. Will have pics posted some time soon. <IMG SRC="smilies/wink.gif" border="0"> <IMG SRC="smilies/beer.gif" border="0">
Its about 5 in the front and unknown in the rear I just started putting leafs to gether till I got the hiegt i wanted
On the front flairs i marked 2 of the bolt holes with a marker drilled those 2 out bolted the flaie on then marked the rest of the holes and the cut line on the bottom of the flair and started whacking away with it
It is pretty easy and the flairs hide the cut so it doesn't matter if it look bad at the cuts just gonna hide it anyway
I did something similar with mine, but I used stock flairs and cut the entire creased part that they were attatched to originally off. They are way higher now and a hell of a lot more open......
1 - 9 of 9 Posts
