1 - 20 of 34 Posts
Title says it all.
I'm having a hard time coming up with a way to mount this that I like. Has to sit ontop of frame, not down between the rails. My steering box is in the way.
Ford Bigot
I had a similar predicament when I built my flat fender. I ended up just buying the Warn winch plate they made for the 8274 and mounting it up.
The good thing is it matches the whole nostalgia thing going for the GPW. It may not be what you want but the plate certainly is sturdy.
Mine's not an 8274 though, it's an old Belleview. I think it actually takes up a little more space on the gearbox side. The mounting pattern is also a bit different......6 bolts instead of 4 and you have to add a hole for the hawse on one side.
first pic on a first gen toyota
not installed, but set up for a 8274.
a bronco
a scout
Im happy with how mine came out. On a side note does anyone know where to buy those square nuts for the mounting bolts? I need 2 and have and have had a hell of a time finding them. Im about to dill and tap some 3/8s, figured id ask first.
1 - 20 of 34 Posts
