mixmaster said:
I haven't been following the other threads so I am curious as to what was wrong with your steering? Are you running hydro or just power steering? Also, did your SR give you any lift? Thanks.
Very strange steering gremlins. It wouldn't turn left. Cleaned the box out with the air comp, replaced the lines, steering u-joint, and now the pump. And presto. All is better.
As for my Shackle reversal. With my current set up, it is actually 3 inches lower than before when I had the shackle in front and just a spring over. I removed 2 leaves from the pack, and over the weekend put one back in it, because it sagged to where I wanted it too. So all in all, it's 3 inches lower and a foot wider. Hopefully this means less pics of the glow belly.
