1 - 20 of 24 Posts
I'm doing an SAS on my 88 Toy, the axle is from an 88 Waggy. I have removed the knuckles, but am waiting to reinstall them untill I get the perches and driveline angles nailed down. Someone on another board expressed concern that my pinion was rotated too far and would cause oiling problems on the pinion bearing. The output is pointing at the transfer case.
You should go a couple of degrees lower then the t-case. Oiling should not be an issue, I've seen worse on rear axles that are used to drive to and from the trail. Just make sure you have all the weight on vehicle on the front end.
I agree, it'll be fine. The only time the bearing needs oiling is when things are spinning and when they are, there is oil flying all over the inside the diff. A couple of degrees down from "straight at the t-case" and you're set.
Thanks. I think I actually set it a couple degrees higher than the case, so I may just grind the tacks and drop it a little. My primary concern is the oiling. However, if rear axles are being done that way, I would think it would work fine. The ring gear should throw some oil at the pinion when in motion as well, shouldn't it?
The weight of the vehicle is on the springs in that shot.
Being a front axle, shouldn't this be a couple of *'s above the t-case?
From what I can tell the front is shackle forward, under compression the front axle is going to swing up toward the t-case, if you point the axle a couple degree's higher you might severely bind the d-line. It's hard to say what exact path the axle may take under compression with lift springs and the front fixed spring mount higher then the shackle mount. A few degrees down is safer then a few degrees up.
Another thing to note about oiling is that even if you drive it in 2wd to the trail, oil will slosh around before you put power to it, so the bearings will be fine.
It's a front axle, why worry about oiling and angles since you probably won't be driving it on the street with the hubs locked for hours at a time. The ring gear will sling oil everwhere.
Now, are your spring perches at the same level? Looks like the driver perch is higher than the passenger side by the thickness of the diff housing. Are you going to shim the pass side spring?
Discussion Starter · #13 ·
I wasn't too worried about the oiling, I just thought I'd double check. Glad to hear the consensus is that I'm worrying too much and should STFU and build it allready. :D
The perches are off, as you noticed. It's about 1/4" difference, I plan to just weld a 1/4" plate to the short side and drill for the center pin.
With it turned up that much i would move the fill plug up though to get the oil level at least back up to where it should be. When you turn the pinion up it turns the fill plug down so you loose oil capacity.
1 - 20 of 24 Posts
