1 - 5 of 5 Posts
I've done a little search and came up empty. I'm throwing a new axle in my CJ and was wondering if there is any specific way to no what my pinion angle should be? The spring perches aren't welded on yet so I can set it where ever works best.
Depends on your driveline setup.
With a double cardan, point the pinion right at the rear output of the tcase. If it were me, and with an SUA, I would point it just a few degrees below the output.
With a single cardan shaft, match the pinion angle to the rear output angle, so they are parallel.
Throwing it in the front or rear?
Discussion Starter #4
It's going in the rear.:D
Both pinion angles should NOT be inline with the Drivrshaft angle.
Keep the pinions fairly flat, you can tip them up a few degrees MAX.
The only time you match the pinion angle with the driveshaft angle, is if you have a fixed yoke output on the transfer case & a CV joint rear Drivrshaft.
OR ... if you cut off the knuckles & rotate them to fix the castor, you can then line up the front pinion with the front Drivrshaft.
Otherwise... Only tip them up a few degrees... Or your castor (front) will be in the negative (bad things will happen).
1 - 5 of 5 Posts
