1 - 3 of 3 Posts
How do you determine pinion and driveline angles when lifting a truck and also when doing a custom 4-link or 3-link thanks
with an angle meter. If you're asking what it's supposed to be, that depends on the driveshaft. If you're running a cv shaft, the pinion points at the case. If you're not, it should be parallel to the case.
with a truck with a 2 piece driveshaft after installing a lift the 2 drive lines should be the same angle by dropping down the carrier right?
1 - 3 of 3 Posts
