I must be completely incompitant cause I fawked her up 2 ways swapping pinion yokes. I set her up with 14in/lbs preload(I thought). After 30mins on the highway the housing was hot enough I couldnt hold my hand on it for more than a second or so. So I did what any ******* would do and pulled off to the side of the freeway and backed the pinion nut off a half turn. :flipoff2: 2 hours of freeway after that the housing was running around 105 degrees(vary hot jacuzzi temp). lol. Do I pull her apart and try to do it right again? or does 105 sound about the correct temp?
Pulled the cover when I got home, no burnt fluid or nothing.
Also the new pinion seal doesnt seem to be working well? Did I melt the last one? It didnt look like there was much to fawk up with the seal.
Charlo
Charlo
